18 years agopreserve_hierarchy assignment
Hi, It seems like Preserve_hierarchy assignment doesn't work in my Quartus. My components are merged together (i don't want that). I could see it (one of my components) in RTL view but I couldn't...
18 years agoHello ,
Do you prefer VHDL ? I am a VHDL user And I prefer to use Attibute to keep the node in Logic Design instead of setting the "preserve register" assignment in the Q II Assignment Editor This applicable to all register nodes There are two useful attributes which are "syn_preserve" and "syn_keep" syn_preserve is used for keeping the register node , avoid being synthesized away syn_keep is used for keeping the net , to my understanding (I am not sure if it's correct) , it keeps the node so that user can find the node in node finder , but it doesnt guarantee the logic is kept there. Usually I focus on the register nodes and I do not care about those combinational nodes in the design Here is an example : In the signal declaration part : signal Din_p0 : std_logic_vector(15 downto 0); attribute syn_preserve : boolean;attribute syn_preserve of din_p0 : signal is true; Then the Din_p0 will be preserved Another Example signal Q0 : std_logic; signal Q1 : std_logic; begin process (clk, A, B) begin if clk = '1' and clk 'event then Q0 <= A and B; Q1 <= A and B; end if; end process; end behavioral; Then Quartus will preserve DFF for node Q0 and node Q1 Hope it helps Samson
