12 years agopre-filled pin assignment file import procedure
Hi, There is an assigment file for DE0 which is filled with all pins of the board. In this file these pins are associated with specific names. --> It is possible to import this file ...
12 years agoThis thread has an example of using Tcl for pin assignments for the DE0-nano board.
http://www.alteraforum.com/forum/showthread.php?t=39765 This Wiki example has Tcl scripts for other boards http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial You can use the "Export project as Tcl file" procedure from Quartus to see what Tcl settings it uses in a project. Cheers, Dave
