10 years agoPowering FPGA During Programming
Hi everyone- I am finalizing a PCB layout using a Max10 FPGA. This PCB will (hopefully) go into production in our small electronics business, and it will usually be programmed by technicians o...
10 years agoOK, thanks everyone!
My whole board runs at 3.3V, which is supplied by a switcher from Linear (the LTC3031). I checked with the Linear engineer, and he confirmed that it would not harm the switcher to backfeed it (although he had some practical reservations). Having said that, I think that we may actually just build a little bed-of-nails programmer and supply the normal voltage to the board for programming. That seems like it is the best and safest way. The way I designed my board, supplying 3.3V via an intercept in the Blaster cable probably *would* work, but I think that it may not be the best way. However, it seems like this would be a common issue, and it would be cool if Altera could come up with an "official" way to do it! :) Robert
