10 years agoPowering FPGA During Programming
Hi everyone- I am finalizing a PCB layout using a Max10 FPGA. This PCB will (hopefully) go into production in our small electronics business, and it will usually be programmed by technicians o...
10 years agoHi Robert,
One quick clear idea I can think of is MAX10 has on-chip Configuration Flash Memory. You can design a simple Programmer board to Program the Configuration flash (Similar to old days micro-controller used to be programmed with the binaries). In the product line the technician can program the Chip using the programmer board & then assemble it on the daughter card. Regards, Ritesh
