17 years agoPower supply question for EP3C16 Device?
Currently I am using Cyclone III EP3C16. I will use 3.3V for all VCCIO, and 1.2V for VCCINT. When I check the pin information for this device, I found that it is required that the supply (ana...
17 years agoThe 2.5V has to be connected, otherwise the device is hold in reset. A customer has used a silicon diode to generate an about 2.5V voltage from 3.3V, it alsways worked without problems. The good thing with Cyclone III is, that the PLL supply is less critical than with previous families, cause the analog PLL supply has internal voltage regulators powered from VCCA.
