19 years agoPower on Reset & state machines
Hi, I am using MAX II cplds & have a couple of questions. Can anyone explain to me what state a state machine goes into after Power-Up? if My State_type definition is this: type STATE_TYPE is (A,B...
19 years agoBrad, wow thanks, nice quick reply, really appreciate it! I think I understand what your saying , but let me make sure. So you would tie an input pin high, & read it & then when you read a high, you know you've entered user mode & everything should be cleared. Then you'd generate a reset signal based on this sample of a high.. so in the vhdl world, it would be something like this?:
the pin i tied high is input_pin my generated reset is umm.. generated_reset :) process(clk) begin if clk = '1' and clk'event if input_pin = '1' and reset_done = '0' then reset_done <= '1'; generated_reset <= '1'; elsif generated_reset = '1' then generated_reset <= '0'; end if; end if; end process; it should make a generated_reset signal 1 clk cycle wide after entering user_mode, that is of course, if i understand you correctly.. thanks again, ambien
