8 years agoPower decoupling capacitors placement
Hi all! I'm going to develope a board with Cyclone V SoC in UBGA484 or UBGA672 (in both packages distance between balls is 0.8 mm). I have several Terasic development kits with Cyclone V and Cyclo...
8 years ago --- Quote Start --- IMHO you must place decoupling caps directly under the FPGA on the appropriate pins. I do this all the time, using 0402 capacitors and a 0.8mm pitch BGA part. Manufacturing is not a problem, if your vendor can't handle it, many others can. --- Quote End --- Hi, gj_leeson. How do you do that? 0402 is 1*0.5 mm... PCB footprint is about 1.3 *0.6 mm Group several vcc pads and place one capacitor for them? I almost have no experience in PCB routing, so it's not easy for me to understand this approach :) In case of UBGA672 we have some area free of balls inside the package projection, but not all the vcc pins are placed close to this area. And in case of UBGA484 we've got a matrix of balls without any spaces...
