DR123
6 years agoPLL reset input with Dynamic Phase Shifting
Hi, I'm able to dinamically change the phase of an output clock of a PLL, but I have timinig issues on the input reset of the PLL. In particular, Quartus highlights a relation with negative setup sl...
SreekumarR_G_Intel
6 years agoHello, I am not sure about the timing issue you talking about, but about the reset can you use the PLL lock as the reset signal for the internal logic ?
Note : as along as input clock is stable Lock output will be stable .
Can i know why you looking for the reset signal ? i mean any specific reason ?
Thank you ,
Sree
