14 years agoPLL Relock problem
Hi, i used a pll in EP3C40F484, the pll had two clock input pins and a switch input pin. in my logic, i used switch input to select the input clock (inclk0 or inclk1), however, when i changed ...
14 years agoThen read the documentation carefully. Afaik it doesn't switch on switch state change - You need to do a pulse for switching. 0->1 and 1->0.
