14 years agoPLL Relock problem
Hi, i used a pll in EP3C40F484, the pll had two clock input pins and a switch input pin. in my logic, i used switch input to select the input clock (inclk0 or inclk1), however, when i changed ...
14 years agoDo You use PLL core clock switch option or You just have a mux, which select a clock before PLL input?
