11 years agoPLL Reconfiguration/Phase Problem
I'm using a Cyclone IV, Quartus 13.1.0, and have designed a reconfigurable PLL that can be programmed for one of four different output frequencies. There are two PLL outputs, FAST & SLOW, the SLOW o...
11 years agoif initial (pre-reconfig) phase shift for both FAST & SLOW is 0 degree, then whatever MNC counter you reconfigure, expected that you will get a 0 degree phase relationship after a RESET.
what is your initial settings and what did you reconfig? Perhaps i can help you further.
