17 years agoPLL problem after power on reset
Hi, I'm sending data from an arriagx using the lvds block to a stratix fpga, looped through the stratix and back out to the arriagx. There are four lvds blocks involved and each has it's own pl...
17 years agoThe DPA logic has two elements, phase alignment and but alignment. The phase alignment requires edges to be present in the data stream, the bit alignment needs a calibration pattern that allows to determine the bit position unequivocally. Unless you don't use a protocol like 8B/10B coding with embedded sync pattern, you need to indicate the calibration phase to the receiver by an auxilary channel.
