17 years agoPLL problem after power on reset
Hi, I'm sending data from an arriagx using the lvds block to a stratix fpga, looped through the stratix and back out to the arriagx. There are four lvds blocks involved and each has it's own pl...
17 years agoHi Motah,
It might be worth doing further teting before commiting yourself. I mean, you depend on signaltap. I did as well but it could easily mislead due to clock-slip... I sugget you remove signaltap then test your data in a firmware algorithm, check that you receive what you send directly in firmware and raise a flag if not. Your external loop may be as correct as the local. Kaz
