16 years agoPLL outputs to drive 50 ohm loads
I need two outputs from a single PLL of CYCLONE-III 3C16. Both the outputs are single-ended. One of outputs is 100MHz and the other is 120MHz-200MHz which will be dynamically configured through NIOS-...
16 years agoThanks.
One of clocks goes to a high-speed DAC in single-ended mode. In the single-ended mode, it needs 50ohm parallel termination for its best performance. The DAC could accept LVDS. The issue with LVDS from Cyclone-III FPGA is that a bank has to be configured as LVDS. As a result, we don't have enough I/O pins. The other clock (120MHz-200MHz) goes to the single-ended clock input of a device. Ideally, it is in 50ohm parallel termination. I can find up-to 166MHz clock drivers which are able to drive single-ended 50 ohm impedance with 2 inputs being synchronized.
