14 years agoPLL "must be fed by an I/O node"
Hello All, I'm trying to port my design over from X where I use a PLL(DLL) to generate a secondary clock that is slightly advanced so when used on registered outputs produces transitions in pha...
14 years agoHi Scott,
Many thanks for your reply, I am just revisiting this as the PLL solution I had come up with does not seem to work. Yes, I am using the ALTDDIO_OUT 'trick'. This should give the shortest and most deterministic clock->output for all pads on that clock. I'm also inverting it like you suggested, this has worked for me very well in the past. Temporarily I am trying to manually compensate for the output delay using a PLL with a fixed phase shift so that the clock on the pads matches the internal clock, this should be good enough to get me going. Once I get Quartus II v12 installed I will try again to get the PLL feedback to automatically adjust for this. I am having more difficulty than I should be having with this and the documentation is certainly confusing. Regards, ++Simon
