13 years agoPLL Issues
Hi, In my code, I need to do 10MHz to 50MHz PLL and transfer the output to about 10 internal modules. Is it customary and synthesizable? Is there any restriction for Altera PLL fun out Can...
13 years ago --- Quote Start --- Hi, In my code, I need to do 10MHz to 50MHz PLL and transfer the output to about 10 internal modules. Is it customary and synthesizable? Is there any restriction for Altera PLL fun out Can I use direct PLL conversion from 10MHz to 50MHz or should I use PLL to about 100MHz and then use Freq divider to 50MHz. What is your recommendation? Thanks, Idan --- Quote End --- Try 10 => 50MHz PLL then connect 50Mhz to all 10 modules and see if tool is happy. If you run into fanout problems then get several pll outputs at 50MHz. avoid frequency division in logic.
