13 years agoPLL generates some unwanted frequency
Hi I want to interface SDRAM with the Cyclone III FPGA, actually I had successfully interface the SDRAM with Cyclone III FPGA but the problem is when I disable the SDRAM clock (connect the cloc...
13 years agoWhat is "system noise" for you? Where do you connect a spectrum analyzer? Are you talking about radiated interferences?
Generally speaking, a SDRAM in operation will always generate some noise. It strongly depends on your PCB design if it's kept inside the digital circuit or is spread over the system and radiated.
