15 years agoPLL Dynamic Reconfiguration for Stratix III
Hi everyone, I have a scenario where I need to reconfigure a PLL to handle a wide variation in input frequency (100MHz - 250MHz). After doing a little research, the simplest solution seems to...
15 years agoHello,
I managed to implement it and used ALTPLL_RECONFIG; my target device was a Stratix III but I had a different frequency range (40MHz -> 65 MHz). I followed AN 454 as example but developed my own state machine to give a reset to the PLL after it locked. I also used some logic to test the frequency (that board had another clock that was considered "safe" and was used for some built-in tests) and, if necessary, retrigger the reconfiguration. I did it with Quartus II 9.0 and I had problems with the simulation: the result was not identical to physical device (service request suggestion was to use the Advanced Parameters Configuration).
