pktgen-dpdk N3000
Can you provide some logs showing each step that you have taken and what are the outputs.
There is also the INSTALL.md instructions that you must follow on top of what the doc has.
For the hardware, did you connect a cable across both the QSFP?
- ahaa5 years ago
Adding the last reply, here is INSTALL.md of pktgen, and for the limitation of types of uploading files,I
modified it as .txt and you can modify it for your convenience.
And there is a cable connecting QSFP A and B in 8x10G mode.
Thanks very much!
- JonWay_altera5 years ago
Hi, Sorry for the delayed response. Did you resolved this?
You might want to go through the below and see if you missed anything.1) setting the iommu=pt intel_iommu=on pci=realloc
2) Enabling VT-d in BIOS
3) Binding the XL710 and FPGA to vfio-pci drivers
4) Run testpmd
You have to make sure the above were done before you proceed to testing with a pktgen.
- ahaa5 years ago
Here are two files with pktgen and testpmd regarding with my wrong results and comands.
If there are more related info should I provide, please let me know.
Thanks very much for your reply!
