10 years agoPipe to quartus_asm broken but process still running, terminating quartus_asm
I am facing a issue while running a design on QUARTUS 15.0 version. The error comes after the assembler stage while compiling the design. Following is the log - Info: Total CPU time (on all processors): 00:13:54 Info: ******************************************************************* Info: Running Quartus II 64-Bit Assembler Info: Version 15.0.0 Build 145 04/22/2015 SJ Full Version Info: Processing started: Mon Mar 14 17:40:52 2016 Info: Command: quartus_asm --read_settings_files=off --write_settings_files=off system -c system Info: Quartus II 64-Bit Assembler was successful. 0 errors, 0 warnings Info: Peak virtual memory: 7081 megabytes Info: Processing ended: Mon Mar 14 17:42:34 2016 Info: Elapsed time: 00:01:42 Info: Total CPU time (on all processors): 00:01:41 Error (112002): Pipe to quartus_asm broken but process still running, terminating quartus_asm Error (293007): Current module quartus_asm ended unexpectedly ------------------------------------------------ ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last. while executing "execute_flow -compile" (file "synthesis_tcl.tcl" line 21) ------------------------------------------------ Error (23031): Evaluation of Tcl script synthesis_tcl.tcl unsuccessful Error: Quartus II 64-Bit Shell was unsuccessful. 3 errors, 122 warnings Error: Peak virtual memory: 935 megabytes Error: Processing ended: Mon Mar 14 17:42:37 2016 Error: Elapsed time: 00:09:04 Error: Total CPU time (on all processors): 00:15:03 PS - there is enough memory space and OS used is linux. Any help would be worth. Regards, AnmagNo RepliesBe the first to reply
