18 years ago
PIN Connections to SSRAM
I am using Nios II Embedded evaluation Kit (Cyclone III) (EP3C25F324C6)..
My Intension is to read and write data to /from the SSRAM on the board ... in byte manner
Now I have to use SRAM_D0-SRAM_D1 pins to configure the device (SSRAM) to read the data from the SSRAM...
So ,I changed in the device settings (User IO).. to use those pins as user IO . But even then I am unable to get the last byte value correctly..
So, Please suggest me how to use those pins correctly ...
Please help me out of this issue ..
Waiting for a reply ..
Srinath.
    Check whether Byte enables are playing any role in your code. Also, when you say last byte, Do u mean last byte of data that is written to SRAM? What Size{in Bytes} of data have you tried writing to SRAM?
    I really wonder whether last byte is written properly or not!!:mad:
    To confirm.Try this out:
    Write data in multiple bursts linearly and read linearly to observe whether the last byte of every burst is missed out/ not!
    I understood the tiings from the datasheet, but while reading I am unable to read the eaxct data which I have given.
    As mentioned earlier I am getting the error valus for the fianl byte/
    Is there any solution for this issue.
    Srinath.
    Did you understand the cotrol timing requirements of SSRAM from the datasheet?
