12 years agoPin assignments DE4
Hi to all, I have a DE4 Development and Education Board. I'm trying to make a simple project consists of a CPU, an on-chip memory, a jtag-uart, a flash memory (Flash Memory Interface (CFI)), a tri...
12 years agoRegarding the setup times etc - if you're using a standard Altera development board you should be able to specify the FLASH part used in Qsys when you add the FLASH peripheral to your project. Assuming that is the case that library model will setup all the timing parameters for you.
If you want to do it manually then you'll have to refer to the manufacturers data sheet for the particular FLASH part in question.
