RBell9
7 years agoPin Assignment rules
I'm using the Cyclone 10 LP FPGA Evaluation Kit with Quartus II software.
When I try to read the value from the GPIO connector (using an oscilloscope) I read different values depending on which pin I choose (the same signal on a different pin has different values).
I think that the problem is connected with a wrong assignment in the pin planner. There are general rules to assign a pin?
1 Reply
- sstrell
Without knowing the design or how you've assigned pins, it's impossible to answer. Can you provide this information? Screenshot of Pin Planner? Code? Etc.
#iwork4intel
