16 years agoPin assignment in Quartus II
Hi all, After my design is added to the project if I tried to assign the pins automatically using compile Design option or I/O assignment analysis option available under compile design too...
16 years ago --- Quote Start --- Thanks for the reply, But how about if the Address pins are not allocated, i.e if it produces the warning message which I mentioned in previous post. --- Quote End --- Hi, did you have look into the <>.pin file? It is located in your project directory. Could you find all your pins in the file ? Kind regards GPK
