16 years agoPin assignment in Quartus II
Hi all, After my design is added to the project if I tried to assign the pins automatically using compile Design option or I/O assignment analysis option available under compile design too...
16 years ago --- Quote Start --- But I want the allocations in QSF. Lets take an example of Xilinx MIG. If we select any banks for user allocation then the pins get allocated in the selected banks by following pin allocation rules. If we didn't select any banks it 'll proceed with Default bank selections and outputs the UCF(user copnstraints file) with all pin alloctaions. I want the similar way here. Is there any option like that in IPtool bench or Quartus II?. --- Quote End --- Hi, looks like that my post is missing. you can preserve the pin assignment choosen by Quartus. You have to back-annotade the assignment. You can do that in following way: Choose: Assignment -> Back-Annotate Assignments Stay with the default setting "Pin&device Assignment" and press ok. The assignments are now written into the QSF. Kind regards GPK
