16 years agoPin assignment in Quartus II
Hi all, After my design is added to the project if I tried to assign the pins automatically using compile Design option or I/O assignment analysis option available under compile design too...
16 years agoYeah, what you need to do is let Quartus II handle the random pin assignments. I believe it is the same for Xilinx ISE. Then after that, go to pin output file (in txt format) to view the pin report that is assigned by Quartus II
