16 years agoPin assignment in Quartus II
Hi all, After my design is added to the project if I tried to assign the pins automatically using compile Design option or I/O assignment analysis option available under compile design too...
16 years agoLaxmanv. I assume you want to compile your design and stop quartus from warning about assigned pin locations? Is this what your asking?
Normally if your using a dev kit, do not let quartus do pin assigment. However if your on a new design, then just compile it and quartus fitter will assign pins. Then use back annote assignments command.
