16 years agoPin assignment in Quartus II
Hi all, After my design is added to the project if I tried to assign the pins automatically using compile Design option or I/O assignment analysis option available under compile design too...
16 years agoI believe if you want to let Quartus II do the pin assignments for you, you don't have to go to pin assignment. Just compile the project and finish routing. It should be able to assign the pins for you randomly.
