14 years agoPin assignment help needed
Hello, I am new to quartus and would require help with the pin assignment feature(using pin planner). I have created a certain design. In the design it is required that certain inputs are always...
14 years agoHere's my 'basic' top-level design for the Cyclone IV GX Transceiver Starter Kit (C4GXSK). I assume that is the kit you are using.
EDIT: oops, i re-read your post and you say cyclone 3 in it, sorry. anyway, this type of 'basic' template is what i create for every fpga board design. Note the warnings regarding the shared address/data bus. The LCD voltages can damage the FPGA if you do not drive the signals. Cheers, Dave
-- c4gxsk/cyclone4/basic/src/c4gxsk.vhd
-- 3/6/2012 D. W. Hawkins ([email protected])
-- Altera Cyclone IV GX Transceiver Starter Kit basic design.
-- This basic design implements the following;
-- * LED connected to PB
-- * LED blinked by a counter clocked by the 50MHz osc
-- * LED blinked by a counter clocked by the 125MHz osc
-- This top-level design file can be used as the template for all
-- C4GXSK designs. This design file defines the pin directions
-- for all devices on the board (including the unused devices).
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.math_real.all;
entity c4gxsk is
port (
-- CPU reset (push button)
cpu_rstN : in std_logic;
-- Clocks
-- 50MHz oscillator
clkin_50MHz : in std_logic;
-- 125MHz oscillator
clkin_125MHz : in std_logic;
-- User I/O
-- Push buttons
pb : in std_logic_vector(1 downto 0);
-- LEDs
led : out std_logic_vector(3 downto 0);
-- Flash/SRAM/MAX II/LCD (FSML)
-- Flash select
flash_ceN : out std_logic;
-- SSRAM controls
ssram_clk : out std_logic;
ssram_ceN : out std_logic;
ssram_beN : out std_logic_vector(1 downto 0);
-- MAX II select
max2_csN : out std_logic;
-- LCD select
lcd_csN : out std_logic;
-- Common controls
fsml_oeN : out std_logic;
fsml_weN : out std_logic;
-- Address/data buses
fsml_addr : out std_logic_vector(23 downto 0);
fsml_dq : inout std_logic_vector(15 downto 0);
-- Ethernet PHY
-- Reference clock
refclk_enet : in std_logic;
-- Reset
enet_rstN : out std_logic;
-- Interrupt
enet_intN : in std_logic;
-- Management I2C interface
enet_mdc : out std_logic;
enet_mdio : inout std_logic;
-- PHY interface
-- enet_tx : out std_logic;
-- enet_rx : in std_logic;
-- PCIe
-- Reference clock
refclk_pcie : in std_logic;
-- Reset
pcie_perstN : in std_logic;
-- Transceivers
-- pcie_tx : out std_logic;
-- pcie_rx : in std_logic;
-- EPCS (serial EEPROM) interface
epcs_clk : out std_logic;
epcs_csN : out std_logic;
epcs_mosi : out std_logic;
epcs_miso : in std_logic
end entity;
architecture basic of c4gxsk is
-- Parameters
-- Clocks
constant CLK_FREQUENCY_A : real := 50.0e6;
constant CLK_FREQUENCY_B : real := 125.0e6;
-- Counter count required for ~0.5s pulse time on first LED
constant CVALUE_A : real := 0.5*CLK_FREQUENCY_A;
constant CVALUE_B : real := 0.5*CLK_FREQUENCY_B;
-- Counter width required
constant CWIDTH_A : integer :=
integer(ceil(log2(CVALUE_A-1.0)));
constant CWIDTH_B : integer :=
integer(ceil(log2(CVALUE_B-1.0)));
-- Note:
-- The counter count widths are the number of bits required
-- to count for about half a second. This essentially rounds
-- the count up to the nearest power-of-2, so the two LED
-- blink periods will not be the same.
-- When viewing the hardware, you can see the effect of this
-- rounding as the slight difference the relative timing of
-- the two LEDs.
-- Signals
-- Reset (rename the external signal)
alias rstN is cpu_rstN;
-- Counter
signal count_a : unsigned(CWIDTH_A-1 downto 0);
signal count_b : unsigned(CWIDTH_B-1 downto 0);
begin
-- Push-buttons to LEDs
led(1 downto 0) <= pb;
-- LED counters
-- 50MHz clock
process(clkin_50MHz, rstN)
begin
if (rstN = '0') then
count_a <= (others => '0');
elsif rising_edge(clkin_50MHz) then
count_a <= count_a + 1;
end if;
end process;
led(2) <= count_a(CWIDTH_A-1);
-- 125MHz clock
process(clkin_125MHz, rstN)
begin
count_b <= (others => '0');
elsif rising_edge(clkin_125MHz) then
count_b <= count_b + 1;
end if;
end process;
led(3) <= not count_b(CWIDTH_B-1);
-- Unused outputs
-- Flash select
flash_ceN <= 'Z';
-- SSRAM controls
ssram_clk <= 'Z';
ssram_ceN <= 'Z';
ssram_beN <= (others => 'Z');
-- MAX II select
max2_csN <= 'Z';
-- LCD select
lcd_csN <= '1';
-- Common controls
fsml_oeN <= 'Z';
fsml_weN <= 'Z';
-- * explicitly drive the address/data buses low to avoid
-- violating the I/O voltage
-- * if the address bus is tri-stated, and the I/O clamping
-- diodes are not enabled (the default Quartus setting),
-- A0 gets pulled to 4.45V and the other signals get pulled
-- to 2.8V. The voltage is limited on the other signals due
-- to the clamping diodes on the data bus (FPGA), or on other
-- devices (A1 is connected to the SSRAM and Flash).
fsml_addr <= (others => '0');
fsml_dq <= (others => '0');
-- Ethernet PHY
enet_rstN <= '0'; -- hold in reset
enet_mdc <= 'Z';
enet_mdio <= 'Z';
-- PHY transciever interface
-- enet_tx <= '0';
-- PCIe transciever interface
-- pcie_tx <= '0';
-- EPCS
epcs_clk <= 'Z';
epcs_csN <= 'Z';
epcs_mosi <= 'Z';
end architecture;
