16 years agoPin Assignment failed to be downloaded to the FPGA board
Hi, All, I am using the Cyclone II DE board and had a strange problem. Once I changed the pin assignment, e.g., I changed the reset signal from push button KEY0 to KEY1; then I re-compiled...
16 years ago --- Quote Start --- Hello, GPK, Thanks for replying! Now the problem seems have gone. The solution is that I re-added nodes inside the SignalTap each time I changed the pin assignment in Pin Planner, and then re-compile. I am using Quartus II 9.0 SP2. Thanks once again. --- Quote End --- Hi, I observed a similar problem with Quartus II 9.1. When you use post-fitting nodes in Signaltap the Partition Top ( that is a defalut partition in every project) preserve Level is set to "Placement & Routing" and a new pin assignment will be ignored. Look into your messages, I sure sure you will find an info about this issue. Kind regards GPK
