16 years agoPin Assignment failed to be downloaded to the FPGA board
Hi, All, I am using the Cyclone II DE board and had a strange problem. Once I changed the pin assignment, e.g., I changed the reset signal from push button KEY0 to KEY1; then I re-compiled...
16 years ago --- Quote Start --- first have look into the <>.pin file. It is locaterd in the Quartus RunDir. Search for your signal and check whether the assignment changed or not. If not, how do you change the assignment ? Using the Assignment Editor ? Which Version of Quartus do you use ? Kind regards GPK --- Quote End --- Hello, GPK, Thanks for replying! Now the problem seems have gone. The solution is that I re-added nodes inside the SignalTap each time I changed the pin assignment in Pin Planner, and then re-compile. I am using Quartus II 9.0 SP2. Thanks once again.
