14 years ago
Pid control algorithm
Please help to trouble shooot thos code for likely errors cos it's not compiling. Then as a beginner to programming I want to know if the programme will compile work as a PID Controller
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity pid is
port
-- input ports
clk : in std_logic;
reset : in std_logic;
e_in : in signed ((data_width-15) downto 0);
setpoint : in signed ((data_width-15) downto 0);
variable k0 : std_logic_vector(15 downto 0);
variable k1 : std_logic_vector(15 downto 0);
variable k2 : std_logic_vector(15 downto 0);
-- output ports
u_out : out signed ((data_width-15) downto 0);
end entity;
architecture behavioral of pid is
component dff
port(
q : out signed(15 downto 0); --output connected to the adder
clk :in std_logic; -- clock input
d :in signed(15 downto 0) -- data input from the mcm block.
end component;
--read from adc value
y <= adc :in signed(15 downto 0);
e_in <= setpoint - y
-- initializations of parameters
signal mcm0,mcm1,mcm2,add_out: signed(15 downto 0);
signal q1,q2,q3 : signed(15 downto 0);
-- latching of signals using d flipflop to introduce delay
begin
dff1 : dff port map(q1,clk,u_out);
dff2 : dff port map(q2,clk,e_in);
dff3 : dff port map(q3,clk,e_in);
end
-- storing outputs of the d flipflops
u_prev <= q1;
e_prev(1) <= q2;
e_prev(2) <= q3;
--multiple constant multiplications.
mcm0 <= k0*e_in;
mcm1 <= k1*e_prev(1);
mcm2 <= k2*e_prev(2);
--adders
add_out1 <= mcm0 + mcm1;
add_out2 <= add_out1 + mcm2;
u_out <= u_prev + add_out2
--an output produced at every positive edge of clock cycle.
process
begin
if(rising_edge(clk)) then
if <reset == 1> then
u_prev <= 0;
e_prev[1] <= 0;
e_prev[2] <= 0;
else
e_prev[2] <= e_prev[1];
e_prev[1] <= e_in;
u_prev <= u_out;
end if;
end if;
end process;
end behavioral pid;
--vhdl code for the component dff is given below:
library altera;
use altera.altera_primitives_components.all;
entity dff is
begin
port(
end dff;
architecture behavioral of dff is
signal qt : signed(15 downto 0) := (others => '0');
begin
q <= qt;
process(clk)
begin
if ( rising_edge(clk) ) then
qt <= d;
end if;
end process;
end behavioral;
1 Reply
    --- Quote Start ---
    I want to know if the programme will compile work as a PID Controller.
    --- Quote End ---
    Only after a longer phase of correcting the massive VHDL syntax and semantic errors as well as PID implementation faults. IMHO there isn't much hope without studying the basic VHDL concepts more thorougly.
