15 years agophysical interface between Cyclone III & DAC
Hello to all, I am working on a test waveform generator project using the Cyclone III starter kit (3C25N). Once synthesized on the FPGA, the waveform will be sent to a DAC so that it can be vi...
15 years ago --- Quote Start --- Does that mean that I can't output an analog signal with a DC offset? --- Quote End --- Look at the DAC5672 eval module schematic on p25 http://focus.ti.com/lit/ug/slau139b/slau139b.pdf Its a transformer coupled output via a T1-1T, which is a minicircuits part http://www.minicircuits.com/pdfs/t1-1t-kk81.pdf So you have an output bandwidth limitation of 0.08-200MHz. However, its your evaluation board once you've paid for it, so hack it at will. However, you will need to buffer the output if you remove the transformer. Cheers, Dave
