15 years agophysical interface between Cyclone III & DAC
Hello to all, I am working on a test waveform generator project using the Cyclone III starter kit (3C25N). Once synthesized on the FPGA, the waveform will be sent to a DAC so that it can be vi...
15 years ago --- Quote Start --- You can review the documentation of the Terasic THDB_ADA board, that can connect to the C3 starter kit. --- Quote End --- After reviewing the documentation, I noticed the following line: "DA and AD converters do no support DC signalling" Does that mean that I can't output an analog signal with a DC offset?
