15 years agoPFL with S4 and MAXii
Hi I encounter an issue while using a PFL (FPP) configuration scheme. Actually: -- the Flash memory is correctly seen by the CFI and well programmed -- the configuration has the following be...
15 years agoHi,
I am having a similar problem with the PFL (FPP) scheme. I have a Max II act as the configuration controller, which load configuration data from a flash and configure a Stratix IV FPGA. (All terminologies I use here are according to the Parallel Flash loader userguide.) I followed the Parallel Flash loader megafunction user guide to create a project for Max II. Currently, I can see that whenever the fpga_nconfig line generates a low pulse, the fpga_nstatus follows with a low pulse, and the fpga_conf_done goes to low. But nothing happens afterwards, I don't see a fpga_dclk being generated by the MAX II. However, I do see the pfl_clk working properly. I kept the pfl_nreset input to high at all time. Can you provide more details on how to debug the PFL megafunction, and give me some hint please? Cheers, Han
