15 years agoPFL with S4 and MAXii
Hi I encounter an issue while using a PFL (FPP) configuration scheme. Actually: -- the Flash memory is correctly seen by the CFI and well programmed -- the configuration has the following be...
15 years agoHi Pete
And thank you for your reply. I don't believe that I have this issue cause it happens to work well. In fact, I believe that I have a timing issue somewhere. When I stated that the MAXii PFL design does nothing, I meant that, possibly, it has considered that the S4 simply needs nothing. That was the purpose of my question regarding the sample timing diagram. I assume that the PFL design monitors the configuration wires and would decide to start or not the cfg cycle. This is my missing info. I will start to simulate, but I do not know if this would work as the AN states that one can not..... Regards Thomas
