Matt1
8 years agoPFL Mega Function: Setup time Issue
hi all, I am trying to implement Altera PFL IP (configuration is done for FPPx16) in MAX5 CPLD. As per the datasheet i did all the constraining for the respective signals. From the CPLD design com...
Matt1
8 years agoHello Alex & GNg,
thank you for the support.
Is it recommended to use some of the optimizing options which is available in Quartus tool to make it work close to 100Mhz?
@GNg, referring to ug_pfl.pdf, table 7 states that pfl_clk "Can be constrained up to the maximum frequency supported by the PFL IP core"'.
but I couldn't find any document which specifies the Fmax of PFL IP.
is there any document which give the reference of the Fmax ( pfl ip )for a series of cpld devices ?
what I meat is ,for example MAX V(part number:5Mxxxxxxxx) can support Fmax of X Mhz .
thanks
