14 years agoPCIE Hard IP for for HSMC port
Hi, In Cyclone IVGX development kit (NOT the starter kit) with EP4CGX150DF31, the schematic shows that the PCIE hard ip is available for transceiver block GXBL0 - transceiver channels 0-3 (PCIE x4...
14 years ago --- Quote Start --- Hi, In Cyclone IVGX development kit (NOT the starter kit) with EP4CGX150DF31, the schematic shows that the PCIE hard ip is available for transceiver block GXBL0 - transceiver channels 0-3 (PCIE x4 or HSMC XCVR PORT B ). My doubts are: 1. Does this mean that i can use pcie hard ip if i wish to initiate PCI express connection via HSMC port B (not the pcie edge connector)? 2. The user guide also states that HSMC port B only supports single ended signaling. Will that be an issue if i want to use PCIE connection via the HSMC port B? regards. --- Quote End --- Hi Barron, Did you able to find answers to your questions above? I am having the same questions in mind. Can you (or anyone) please shed some light here?
