12 years agoPCIe Gen-1 Application clock
Hi, We are planning to use PCIe Gen-1 core on Stratix IV GX device. As per datasheet, minimum Application/core clock is 62.5 MHz. Is it possible, to reduce Application clock less than 62.5 MHz?...
12 years agoIIRC the 'Application clock' from the PCIe block is the clock that it's application side logic (Avalon (etc) interface) runs at.
If you clock your logic from a different clock then qsys will (silently) add the appropriate clock crossing bridges.
