12 years agoPCIe Gen-1 Application clock
Hi, We are planning to use PCIe Gen-1 core on Stratix IV GX device. As per datasheet, minimum Application/core clock is 62.5 MHz. Is it possible, to reduce Application clock less than 62.5 MHz?...
12 years agoI doubt Altera will support you if you chose to run the core below the minimum clock speed.
Can you not increase the frequency of your system, or part of your system to ensure you comply with the minimum frequency? Cheers, Alex
