PCIe bridge crash on Icelake-SP running pktgen on multiple ports
Which IP you are using? can you share the .ip settings?
[root@HWHA3300011 log]# modinfo ice
filename: /lib/modules/4.18.0-372.32.1.rt7.189.el8.x86_64/updates/drivers/net/ethernet/intel/ice/ice.ko
firmware: intel/ice/ddp/ice.pkg
version: 1.9.11
license: GPL v2
description: Intel(R) Ethernet Connection E800 Series Linux Driver
author: Intel Corporation, <[email protected]>
rhelversion: 8.6
srcversion: 06B8AD97B187AB8A177D9BB
alias: pci:v00008086d00001888sv*sd*bc*sc*i*
alias: pci:v00008086d0000579Fsv*sd*bc*sc*i*
alias: pci:v00008086d0000579Esv*sd*bc*sc*i*
alias: pci:v00008086d0000579Dsv*sd*bc*sc*i*
alias: pci:v00008086d0000579Csv*sd*bc*sc*i*
alias: pci:v00008086d0000151Dsv*sd*bc*sc*i*
alias: pci:v00008086d0000124Fsv*sd*bc*sc*i*
alias: pci:v00008086d0000124Esv*sd*bc*sc*i*
alias: pci:v00008086d0000124Dsv*sd*bc*sc*i*
alias: pci:v00008086d0000124Csv*sd*bc*sc*i*
alias: pci:v00008086d0000189Asv*sd*bc*sc*i*
alias: pci:v00008086d00001899sv*sd*bc*sc*i*
alias: pci:v00008086d00001898sv*sd*bc*sc*i*
alias: pci:v00008086d00001897sv*sd*bc*sc*i*
alias: pci:v00008086d00001894sv*sd*bc*sc*i*
alias: pci:v00008086d00001893sv*sd*bc*sc*i*
alias: pci:v00008086d00001892sv*sd*bc*sc*i*
alias: pci:v00008086d00001891sv*sd*bc*sc*i*
alias: pci:v00008086d00001890sv*sd*bc*sc*i*
alias: pci:v00008086d0000188Esv*sd*bc*sc*i*
alias: pci:v00008086d0000188Dsv*sd*bc*sc*i*
alias: pci:v00008086d0000188Csv*sd*bc*sc*i*
alias: pci:v00008086d0000188Bsv*sd*bc*sc*i*
alias: pci:v00008086d0000188Asv*sd*bc*sc*i*
alias: pci:v00008086d0000159Bsv*sd*bc*sc*i*
alias: pci:v00008086d0000159Asv*sd*bc*sc*i*
alias: pci:v00008086d00001599sv*sd*bc*sc*i*
alias: pci:v00008086d00001593sv*sd*bc*sc*i*
alias: pci:v00008086d00001592sv*sd*bc*sc*i*
alias: pci:v00008086d00001591sv*sd*bc*sc*i*
depends:
vermagic: 4.18.0-372.32.1.rt7.189.el8.x86_64 SMP preempt_rt mod_unload modversions
parm: debug:netif level (0=none,...,16=all) (int)
parm: fwlog_level:FW event level to log. All levels <= to the specified value are enabled. Values: 0=none, 1=error, 2=warning, 3=normal, 4=verbose. Invalid values: >=5
(ushort)
parm: fwlog_events:FW events to log (32-bit mask)
- Zhaoxuan12 years ago
Which IP did you choose and compile in Quartus? Could you share the IP parameters you set in platform designer? Which tile are you using? Could you share device messages before/after encounting errors with lspci -vvvs B:D.F command?
Best Regards
Zhao Xuan
