16 years ago
Pattern inclusion
Hallo there,
I need some help or ideas,
i have a data stream and one time in this stream i have a frame "80008000" the next frame is then a counter value, for example "00000008"
and then again "normal" frames (for me not interesting how they look).
Now when i found this "80008000" i have to read out the next frame (counter value) and then i have to fill in the stream on this location with "80008000" frames. I have to fill in this frame as often as the counter value shows.
How can i do this? Should i take a fifo so that the frames which came after the counter value could be saved for the time i fill in the "80008000" frames?
has anybody an idea how i can do this?
thanks
    --- Quote Start ---
    for what are you waiting?
    --- Quote End ---
    its a spam bot, you should give some negative reps and report the post as spam. :cool:
    you can use shift register to detect any pattern:
    e.g. assuming data_in = 8 bits, for x"80008000" use 32 bit shift register:
    on the clk edge:
    shift_reg <= shift_reg(23 downto 0) & data_in;
    if(shift_reg = x"80008000")then
    action...
    end if;
    take care with byte/shift orientaion(MSB isuses)
    thanks,
    one more question,
    how can i read out the frame after the "80008000" frame?
    I can search for "80008000" and then i want to read out the frame after that,
    how can i realize this in vhdl?
    yes, you either save the incoming frames while you are inserting... or use request signal to stop it...
