12 years agoPassive Serial Tri-state
I am designing a Cyclone IV based board with an SPI interface that we would like to use to configure the FPGA with an MCU. We will configure the pins to toggle like Figure 8-16 (Device Handbook Vol ...
12 years agoNotes to Figure 8–16 in Cyclone IV Device Handbook, March:
(1)... (2) ... (3) ... (4) In user mode, drive DCLK either high or low when using the PS configuration scheme, whichever is more convenient. When using the AS configuration scheme, DCLK is a Cyclone IV device output pin and must not be driven externally. (5) Do not leave the DATA[0]pin floating after configuration. Drive the DATA[0]pin high or low, whichever is more convenient. They didn't say drive staticlly. I think you can connect other pin to these two net directlly. This should also true for pins nStatus and CONF_DONE.
