12 years agoPassive Serial Tri-state
I am designing a Cyclone IV based board with an SPI interface that we would like to use to configure the FPGA with an MCU. We will configure the pins to toggle like Figure 8-16 (Device Handbook Vol ...
12 years agoThe Data and DCLK are inputs in Passive Serial mode, so unless you specifically change the "Dual-Purpose Pins" setting in Quartus to make them GPIO's they will be inputs or tristated.
Check out: Assignments->Device->Device and Pin Options->Dual-Purpose Pins.. What pins are dual purpose may change from family to family. So make sure you are checking the pin settings for the device you need.. Pete
