13 years ago
partially assigning values to std_logic_vector array
Hi to all,
I have declared the following type and i have a problem , how should i assigning the x,y, and D std_logic vector (8 bit ) to the pixel ( 24 bit) in the following order pixel ( x(8 bit),y(8 bit),d(8 bit))
TYPE ref_array IS Array (natural Range<>) of std_logic_vector(23 DOWNTO 0);
signal ref_array_xyd : ref_matrix (0 to 25343);
for i IN ref_array_xyd'Range LOOP
ref_array_xyd(i) ( 7 down to 0)<= data;
ref_array_xyd(i) ( 8 down to 15)<= data;
ref_array_xyd(i) ( 16 down to 23)<= data;
END LOOP;
is this right??? please, help
sam
    You can also write this as:
     ref_array_xyd <= (others => (datad & datay & datax));
    Be aware that an array of 25344 24 bit std_logic_vectors uses more LEs than you will have in your FPGA, except for the biggest Stratix IV and V ones (which cost a small fortune ...)
    --- Quote Start ---
    --- Quote End ---
    In other words, the design isn't synthesizable under practical condiderations.
