17 years agoOutput_Pin tming not met in TimeQuest.
Hi I have a problem in TimeQuest. Timing requirement mot met from regster to output_pin. //********************** My .sdc file contain following commands set_output_delay -max 0.2 -c...
17 years agoI'm having a similar problem, except that I have PLL and I think I have constrained everything correctly. Here's my timing report:
Data Arrival Path
Total Incr Type Element
0.000 0.000 launch edge time
0.326 0.326 clock network delay
0.558 0.232 uTco out~reg0
0.558 0.000 CELL out~reg0|q
2.203 1.645 IC out~output|i
4.355 2.152 CELL out~output|o
4.355 0.000 CELL out
Data Required Path
5.000 5.000 latch edge time
5.000 0.000 clock network delay
4.910 -0.090 clock uncertainty
3.410 -1.500 oExt out
As you can see, I have "set_output_delay 1 [get_ports out] -clock clk", and clk has been compensated with PLL. However, there's still non-zero clock tree delay and the IOOBUF has a really big delay. What can I do to close the output timing? Note that I need ~1ns improvement. So even if the clock tree has 0ns insertion delay it won't help.
