10 years agoOutput Grayscale Image through VGA in DE1
I am trying to make a project wherein I will capture an image thru DE1 D5M camera module and then convert the image to grayscale then show the ouptut thru VGA in a monitor. How can I do this? I mean,...
10 years agoI tired to edit the DE1_D5M code given by altera. From there, I wanted to convert the RGB image to grayscale from a separate module and then output it to VGA.
Part of my top module is here:
assign DISP_R = SW ? GrayscaleR : VGA_out_R;
assign DISP_G = SW ? GrayscaleG : VGA_out_G;
assign DISP_B = SW ? GrayscaleB : VGA_out_B;
// RGB
assign VGA_out_R = Read_DATA2;
assign VGA_out_G = {Read_DATA1,Read_DATA2};
assign VGA_out_B = Read_DATA1;
// Gray
assign GrayscaleR = VGA_out_G;
assign GrayscaleG = VGA_out_G;
assign GrayscaleB = VGA_out_G;
assign VGA_CTRL_CLK= rClk;
assign VGA_CLK = ~rClk;
always@(posedge CLOCK_50) rClk <= rClk+1;
wire oVGA_R;
wire oVGA_G;
wire oVGA_B;
assign VGA_R = oVGA_R;
assign VGA_G = oVGA_G;
assign VGA_B = oVGA_B;
always@(posedge CCD_PIXCLK)
begin
rCCD_DATA <= CCD_DATA;
rCCD_LVAL <= CCD_LVAL;
rCCD_FVAL <= CCD_FVAL;
end
VGA_Controller u1 ( // Host Side
.oRequest(Read),
.iRed(DISP_R),
.iGreen(DISP_G,
.iBlue(DISP_B),
// VGA Side
.oVGA_R(VGA_R),
.oVGA_G(VGA_G),
.oVGA_B(VGA_B),
.oVGA_H_SYNC(VGA_HS),
.oVGA_V_SYNC(VGA_VS),
// Control Signal
.iCLK(VGA_CTRL_CLK),
.iRST_N(DLY_RST_2)
