14 years agooutput GPIO on DE2
Hello I m trying to use the output GPIO on the DE2 board and cannot even get the clock to output. I have pin one out of a breakout board running through a 1k and then to Comm. My code was imme...
14 years agoDave,
Thanks for your help. I checked my breakout board and it works and is labeled correctly I double checked the pin list and the schematics and it is correct. Still when I hold a multi-meter across the com and 00 or 01 and flip switch 1 I see no change in voltage. Is the pin floating? I cannot get anything from the pins. Am I using the wrong comms? are certain grounds only for certain pins? This is really confusing and frustrating. Are the pins sinking only? How should I go about checking them? Thanks Bill
