14 years agooutput GPIO on DE2
Hello I m trying to use the output GPIO on the DE2 board and cannot even get the clock to output. I have pin one out of a breakout board running through a 1k and then to Comm. My code was imme...
14 years ago --- Quote Start --- Do I assign like this? GPIO_1(1) <=clock_27; --- Quote End --- Yep, like that. Perhaps clock_27 has an issue. Why not start with
GPIO_1(0) <= '0';
GPIO_1(1) <= '1';
And see if you get the two different voltage levels on your GPIO pins. If you don't want to probe with a voltmeter or scope, use the LEDs. Cheers, Dave
