15 years agooutput error clocks from PLL
HI! Everyone! I met a strange question before. the source clock is 48Mhz, So I want to use a PLL to get c0(CLK_25MHz) and c1(CLK_100MHz).But when I use Modelsim and SIgnalTap II for verification,the...
15 years agokaz,
Thanks for your reply, In the Design, I used the ouput clcok c1(CLK_100MHz) to sample data, But the sampling clock I used in the SignalTap II is the source clock(48MHz), I can't understand If there is any relation between the two sampling clock used in different area, So Can you make it more clear,many thanks!
